Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: step 1, image 1 of 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: step 1, image 2 of 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: step 1, image 3 of 3
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: step 2, image 1 of 2 Shark Navigator Lightweight Upright Hose Replacement: step 2, image 2 of 2
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: step 3, image 1 of 3 Shark Navigator Lightweight Upright Hose Replacement: step 3, image 2 of 3 Shark Navigator Lightweight Upright Hose Replacement: step 3, image 3 of 3
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
Kahye Yu
446 Reputation
2 Guides authored
Cal Poly, Team S4-G6, Livingston Fall 2017 Member of Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Members
12 Guides authored
3 Comments
Where can I find a replacement hose?
Vance Payne - Reply
How to replace the bottom pick up hose.
rgg20319 - Reply
How to fix the bottom hose?
rgg20319 - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 59
All Time: 3,475
