Shark Navigator Motor Replacement
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: step 1, image 1 of 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: step 2, image 1 of 2 Shark Navigator Motor Replacement: step 2, image 2 of 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: step 3, image 1 of 1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: step 4, image 1 of 1
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
Molina Oung
289 Reputation
1 Guide authored
6 Guide Comments
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - Reply
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - Reply
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Have no suction but the roller still spins can it still be the Motor ?
Thompson Mick - Reply
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 166
All Time: 17,793
