This teardown is not a repair guide. To repair your Shark Professional Steam Pocket Mop, use our service manual.
  1. Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: step 1, image 1 of 2 Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: step 1, image 2 of 2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Front Panel Disassembly: step 2, image 1 of 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 2, image 2 of 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 2, image 3 of 3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Front Panel Disassembly: step 3, image 1 of 2 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 3, image 2 of 2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Front Panel Disassembly: step 4, image 1 of 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 4, image 2 of 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 4, image 3 of 3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Front Panel Disassembly: step 5, image 1 of 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 5, image 2 of 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: step 5, image 3 of 3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Front Panel Disassembly: step 6, image 1 of 1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
Brett Wilson
992 Reputation
6 Guides authored
USF Tampa, Team S15-G1, Boczar Spring 2018 Member of USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
4 Members
14 Guides authored
One Comment
Here is a video to help with dismantling if you'd like to see the possible original guide first posted on YouTube by George Robles September 16, 2015 years before.
https://youtu.be/18mMbbMjqzs
No one knew or posted before me because I looked everywhere and why I created the video.
But I am curious where you got your information from if it was not my video.
George Robles - Reply
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 76
All Time: 4,066
