Shark Rocket Powerhead AH401 Brushroll Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: step 1, image 1 of 3 Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: step 1, image 2 of 3 Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: step 1, image 3 of 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Replacement: step 2, image 1 of 2 Shark Rocket Powerhead AH401 Brushroll Replacement: step 2, image 2 of 2
    • Lift the brushroll out by pulling the tab labeled "pull".
Toan Pham
269 Reputation
3 Guides authored
Cal Poly, Team S19-G3, Livingston Winter 2018 Member of Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Members
18 Guides authored
One Comment
Can we still get filters (foam & Cotton) for a AH452 Shark, Rocket Powerhead Vacuum?
Olive August - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 938
