Shark Rocket Zero-M Belt Replacement
  1. Shark Rocket Zero-M Belt Replacement, Belt: step 1, image 1 of 1
    • Flip the vacuum on its right side.
  2. Shark Rocket Zero-M Belt Replacement: step 2, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 2, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 2, image 3 of 3
    • Turn the T10 Security Bit screwdriver counterclockwise to remove the 15mm screw.
  3. Shark Rocket Zero-M Belt Replacement: step 3, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 3, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 3, image 3 of 3
    • Turn the vacuum face down.
  4. Shark Rocket Zero-M Belt Replacement: step 4, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 4, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 4, image 3 of 3
    • Use a spudger to pry the side of the vacuum open.
  5. Shark Rocket Zero-M Belt Replacement: step 5, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 5, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 5, image 3 of 3
    • Use a spudger to pry the old belt away from the two gears.
    • The new belt will be tight and difficult to put back on. In order to reinstall, place the belt on the brushroll, then rotate the brushroll a couple rotations to make sure the belt is aligned correctly.
  6. Shark Rocket Zero-M Belt Replacement: step 6, image 1 of 1
    • Repeat on the other side of the vacuum.
Nadia Martinez
133 Reputation
1 Guide authored
One Comment
What is the belt part number looking but can not fine.
Help would be greatly appreciated thank you
jason kennedy - Reply
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 54
All Time: 3,406
