Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement
  1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement, Hose and Wand Attachment: step 1, image 1 of 1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Place the vacuum upright and locate the attachment you want removed.
  2. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 2, image 1 of 3 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 2, image 2 of 3 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 2, image 3 of 3
    • Slide the attachments off of the end of the wand.
    • Some attachments may have a "Release" button--if so, hold down the button while sliding the attachment off.
    • The back of the vacuum has slots to hold up to two vacuum attachments. To store, simply place the attachment onto the circular slots.
  3. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 3, image 1 of 2 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 3, image 2 of 2
    • Locate the button that says “Release Wand” and press down.
    • Press button while lifting upwards on the handle at the top of the wand.
  4. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 4, image 1 of 2 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: step 4, image 2 of 2
    • Locate the black hose on the back of the vacuum.
    • Locate the silver release levers on the top and bottom of the hose.
    • Press on the silver release levers and pull up and away from the device to release the hose.
Samantha Woo
330 Reputation
2 Guides authored
Cal Poly, Team S15-G7, Livingston Fall 2017 Member of Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
4 Members
10 Guides authored
4 Comments
I cannot figure out how to attach het attachments for my new Shark Rotary 752. They just will not go in.
Sandra Groeninger - Reply
I have a shark duoclean Hv3900k and have attached the dusting accessory but I can't get it off after hoovering my staircase
ac002n1397 - Reply
A small white plastic ring which attaches the hose to the junction of the rotating part of machine. the model is NV50101, Shark Rotator Professional. Since I can't keep the hose connected to the vacuum, it cannot be used.
Gilda Allen - Reply
The small white plastic ring on the bottom of the hose is broken and thus the hose will not lock into place.
Gilda Allen - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 98
All Time: 18,576
