Shark Rotator NV502 Foam Filter Replacement
  1. Shark Rotator NV502 Foam Filter Replacement, Foam Filter: step 1, image 1 of 1
    • Locate and press the tab on the top of the removable canister.
    • Lift the canister away from the body of the vacuum.
  2. Shark Rotator NV502 Foam Filter Replacement: step 2, image 1 of 1
    • Look inside the tall hole to locate the foam filter inside.
    • Pull out the foam filter.
  3. Shark Rotator NV502 Foam Filter Replacement: step 3, image 1 of 1
    • Remove the felt filter just below the foam filter
    • Clean or Replace the filters. Let the filter dry before reinserting.
Samuel
307 Reputation
3 Guides authored
Cal Poly, Team 4-3, Livingston Fall 2016 Member of Cal Poly, Team 4-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G3
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 1,964
