Shark Rotator Powered Lift-Away Speed Filter Replacement
  1. Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: step 1, image 1 of 3 Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: step 1, image 2 of 3 Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: step 1, image 3 of 3
    • Press on the lift away button and pull away from the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Filter Replacement: step 2, image 1 of 2 Shark Rotator Powered Lift-Away Speed Filter Replacement: step 2, image 2 of 2
    • Press down on the hose release button and pull away from the vacuum.
  3. Shark Rotator Powered Lift-Away Speed Filter Replacement: step 3, image 1 of 3 Shark Rotator Powered Lift-Away Speed Filter Replacement: step 3, image 2 of 3 Shark Rotator Powered Lift-Away Speed Filter Replacement: step 3, image 3 of 3
    • Pull the dust cup release latch and lift the dust cup from where it rests.
  4. Shark Rotator Powered Lift-Away Speed Filter Replacement: step 4, image 1 of 2 Shark Rotator Powered Lift-Away Speed Filter Replacement: step 4, image 2 of 2
    • Pull out the foam filter from where the dust cup rested.
  5. Shark Rotator Powered Lift-Away Speed Filter Replacement: step 5, image 1 of 2 Shark Rotator Powered Lift-Away Speed Filter Replacement: step 5, image 2 of 2
    • Pull out the felt filter from where the foam filter rested.
Sujey Ruano
706 Reputation
3 Guides authored
Cal Poly, Team S4-G6, White Fall 2018 Member of Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 37
All Time: 3,284
