Shark Rotator Powered Lift-Away Speed Hose Replacement
  1. Shark Rotator Powered Lift-Away Speed Hose Replacement, Hose: step 1, image 1 of 2 Shark Rotator Powered Lift-Away Speed Hose Replacement, Hose: step 1, image 2 of 2
    • Press down on the hose release button and pull away from the vacuum
  2. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 2, image 1 of 3 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 2, image 2 of 3 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 2, image 3 of 3
    • Press down on the wand release button and remove the wand from the vacuum.
  3. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 3, image 1 of 3 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 3, image 2 of 3 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 3, image 3 of 3
    • Press down on the handle release button and pull the wand away from the vacuum.
  4. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 4, image 1 of 2 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 4, image 2 of 2
    • Remove five 13.4 mm screws from the handle with a T20 Torx bit.
  5. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 5, image 1 of 1
    • Using a T20 Torx bit, remove the two 13.4 mm screws from the front of the nozzle.
  6. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 6, image 1 of 3 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 6, image 2 of 3 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 6, image 3 of 3
    • Remove the neck ring by placing a spudger under the brace and lifting outwards.
    • It may be helpful to use a heat gun on the brace and then attempt removing with a spudger.
  7. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 7, image 1 of 1
    • Run the spudger along the center seam of the handle, pulling it apart as you go.
  8. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 8, image 1 of 2 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 8, image 2 of 2
    • Remove the single 13.4 mm screw at the bottom of the handle grip and then lift the grip with a spudger.
  9. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 9, image 1 of 2 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 9, image 2 of 2
    • Remove the single 13.4 mm screw from underneath the handle grip. You are then able to open the handle using a spudger and pulling the pieces apart.
  10. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 10, image 1 of 2 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 10, image 2 of 2
    • Using two spudgers, unclip the hose from the handle.
  11. Shark Rotator Powered Lift-Away Speed Hose Replacement: step 11, image 1 of 2 Shark Rotator Powered Lift-Away Speed Hose Replacement: step 11, image 2 of 2
    • Use wire cutters to clip the white and black wire that connect the hose to the handle.
    • Soldering or wire connectors are necessary for reassembly.
    • Any time you are dealing with electrical components, be sure the device is unplugged.
3 other people completed this guide.
Sujey Ruano
706 Reputation
3 Guides authored
Cal Poly, Team S4-G6, White Fall 2018 Member of Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Members
12 Guides authored
2 Comments
Very helpful! I got a sock super stuck. I tried all the conventional methods to get it out but ended up needing to take the hose apart. Excellent instructions that got the job done with no lasting damage.
Jason Woehl - Reply
My Shark Vertex looks suspiciously like this unit. Maybe I should return it before I have problems that require me to do all this!
My first Shark lasted almost 20 years without a hitch. It was finally taken down by a plastic part inside the unit that I have been unable to locate. It would be quite an easy repair save the plastic part securing the handled hose to the body.
Yikes!
Edward Darbonne - Reply
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 203
All Time: 9,249
