Shark Rotator Powered Lift-Away Suction Hose Replacement
  1. Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Top portion of the Suction Hose: step 1, image 1 of 2 Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Top portion of the Suction Hose: step 1, image 2 of 2
    • On the top portion of the suction hose, firmly press the tab.
    • Next, pull the suction hose up to detach it.
  2. Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Bottom portion of the Hose: step 2, image 1 of 2 Shark Rotator Powered Lift-Away Suction Hose Replacement, Remove the Bottom portion of the Hose: step 2, image 2 of 2
    • On the bottom portion of the suction hose, press the tab and pull the hose out.
2 other people completed this guide.
Junnior Rodriguez
206 Reputation
1 Guide authored
Cal Poly, Team S9-G3, Banghart Fall 2017 Member of Cal Poly, Team S9-G3, Banghart Fall 2017
CPSU-BANGHART-F17S9G3
4 Members
12 Guides authored
One Comment
Base of vac has tear in
Missy McCuthen - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 2,281
