Shark Steam Pocket Mop Ejection Button Assembly Replacement
  1. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: step 1, image 1 of 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: step 1, image 2 of 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Back Panel: step 1, image 3 of 3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: step 2, image 1 of 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: step 2, image 2 of 3 Shark Steam Pocket Mop Ejection Button Assembly Replacement, Ejection Button Assembly: step 2, image 3 of 3
    • Begin by removing the two quarter inch Phillips head screws you see pictured. These screws hold the bottom part of the button assembly to the Mop's midframe.
    • Be very careful not to lose the spring that is in between the top and bottom part of the button assembly.
  3. Shark Steam Pocket Mop Ejection Button Assembly Replacement: step 3, image 1 of 2 Shark Steam Pocket Mop Ejection Button Assembly Replacement: step 3, image 2 of 2
    • Once the bottom piece of the assembly has been removed, carefully turn the mop over and move the front panel of the mop to the side
    • Once you've turned your device over you should be able to remove the top portion of the button assembly with ease. It should not require anything more than your fingers.
Jacob Howe
549 Reputation
5 Guides authored
USF Tampa, Team S13-G7, Cagle Fall 2017 Member of USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 327
