Shark Ultimate Professional Heat Plate Replacement
  1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: step 1, image 1 of 3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: step 1, image 2 of 3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: step 1, image 3 of 3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Heat Plate Replacement: step 2, image 1 of 2 Shark Ultimate Professional Heat Plate Replacement: step 2, image 2 of 2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Heat Plate Replacement: step 3, image 1 of 1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Heat Plate Replacement: step 4, image 1 of 3 Shark Ultimate Professional Heat Plate Replacement: step 4, image 2 of 3 Shark Ultimate Professional Heat Plate Replacement: step 4, image 3 of 3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Heat Plate Replacement: step 5, image 1 of 2 Shark Ultimate Professional Heat Plate Replacement: step 5, image 2 of 2
    • Remove two screws (left and right) affixed to circuit board.
3 other people completed this guide.
Drew Carff
868 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Leahy Fall 2017 Member of USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Members
10 Guides authored
3 Comments
This is an incomplete guide. Why even put it up. So silly and ridiculous. Not Good at all.
Muhammad Ahmad - Reply
Where is the part about the heat plate?
Nealy Moxam - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 2,248
