Shark Ultimate Professional Mode Display Replacement
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: step 1, image 1 of 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: step 1, image 2 of 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: step 1, image 3 of 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: step 2, image 1 of 2 Shark Ultimate Professional Mode Display Replacement: step 2, image 2 of 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: step 3, image 1 of 3 Shark Ultimate Professional Mode Display Replacement: step 3, image 2 of 3 Shark Ultimate Professional Mode Display Replacement: step 3, image 3 of 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: step 4, image 1 of 3 Shark Ultimate Professional Mode Display Replacement: step 4, image 2 of 3 Shark Ultimate Professional Mode Display Replacement: step 4, image 3 of 3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: step 5, image 1 of 2 Shark Ultimate Professional Mode Display Replacement: step 5, image 2 of 2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: step 6, image 1 of 2 Shark Ultimate Professional Mode Display Replacement: step 6, image 2 of 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: step 7, image 1 of 3 Shark Ultimate Professional Mode Display Replacement: step 7, image 2 of 3 Shark Ultimate Professional Mode Display Replacement: step 7, image 3 of 3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
Drew Carff
868 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Leahy Fall 2017 Member of USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 21
All Time: 681
