Shark Ultimate Professional Reservoir Replacement
  1. Shark Ultimate Professional Reservoir  Replacement, Reservoir: step 1, image 1 of 3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: step 1, image 2 of 3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: step 1, image 3 of 3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Reservoir  Replacement: step 2, image 1 of 2 Shark Ultimate Professional Reservoir  Replacement: step 2, image 2 of 2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Reservoir  Replacement: step 3, image 1 of 1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Reservoir  Replacement: step 4, image 1 of 3 Shark Ultimate Professional Reservoir  Replacement: step 4, image 2 of 3 Shark Ultimate Professional Reservoir  Replacement: step 4, image 3 of 3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Black, Red
  5. Shark Ultimate Professional Reservoir  Replacement: step 5, image 1 of 2 Shark Ultimate Professional Reservoir  Replacement: step 5, image 2 of 2
    • Remove two screws (left and right) affixed to circuit board.
3 other people completed this guide.
Drew Carff
868 Reputation
5 Guides authored
3 Guide Comments
i am trying to replace the thermal cutoff but can’s remember the wire inside how to replace
primrose33166 - Reply Share
I have a constant leak in the vertical position - long after the iron is cold. The repair presented is well done. However it stopped short and doesn't get to the reservoir - thanks
Dalmacca-Hame - Reply Share
Then WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT?
Muhammad Ahmad - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 43
All Time: 2,745
