Shark Vertex Pro IZ682H Post-Motor Filter Replacement
  1. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Battery: step 1, image 1 of 1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: step 2, image 1 of 1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: step 3, image 1 of 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: step 3, image 2 of 2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: step 4, image 1 of 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement: step 4, image 2 of 2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
  5. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: step 5, image 1 of 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: step 5, image 2 of 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: step 5, image 3 of 3
    • You will find the post-motor filter in the device under where the dust cup was.
    • The post-motor filter can be easily removed now.
    • Clean the filter with soap and water.
    • Examine your filter for any damage, and if you find any you can buy a replacement on the Shark website.
Tyree Brooks
486 Reputation
5 Guides authored
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 48
All Time: 1,107
