Sharp Aquos Serie mini SHV31 Battery Replacement
  1. Sharp Aquos Serie mini SHV31 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Begin by using a nylon spudger to pry off the back.
  2. Sharp Aquos Serie mini SHV31 Battery Replacement: step 2, image 1 of 2 Sharp Aquos Serie mini SHV31 Battery Replacement: step 2, image 2 of 2
    • Remove case around battery using a T5 screwdriver to remove four 5mm silver screws.
    • Remove two 6mm T5 black screws.
  3. Sharp Aquos Serie mini SHV31 Battery Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to remove the pink clips on either side of the device and then take the casing off.
  4. Sharp Aquos Serie mini SHV31 Battery Replacement, Battery: step 4, image 1 of 1
    • Peel back the grey paper wrapping around the battery.
  5. Sharp Aquos Serie mini SHV31 Battery Replacement: step 5, image 1 of 2 Sharp Aquos Serie mini SHV31 Battery Replacement: step 5, image 2 of 2
    Buy
    • Use the tweezers to remove the Pancake connector that connects the battery to the phone.
Allison Leal
387 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 418
