Sharp EL-510RN Calculator Battery Replacement
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: step 1, image 1 of 2 Sharp EL-510RN Calculator Battery Replacement, Battery: step 1, image 2 of 2
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: step 2, image 1 of 3 Sharp EL-510RN Calculator Battery Replacement: step 2, image 2 of 3 Sharp EL-510RN Calculator Battery Replacement: step 2, image 3 of 3
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: step 3, image 1 of 3 Sharp EL-510RN Calculator Battery Replacement: step 3, image 2 of 3 Sharp EL-510RN Calculator Battery Replacement: step 3, image 3 of 3
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: step 4, image 1 of 3 Sharp EL-510RN Calculator Battery Replacement: step 4, image 2 of 3 Sharp EL-510RN Calculator Battery Replacement: step 4, image 3 of 3
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: step 5, image 1 of 1
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Harish Kugathasalingam
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 47
All Time: 632
