Sharp FX Digitizer/Screen Replacement
  1. Sharp FX Digitizer/Screen Replacement, Digitizer/Screen: step 1, image 1 of 3 Sharp FX Digitizer/Screen Replacement, Digitizer/Screen: step 1, image 2 of 3 Sharp FX Digitizer/Screen Replacement, Digitizer/Screen: step 1, image 3 of 3
    • Remove - Back,microSD,battery,sim
    • Remove black rubber screw covers on back of display.
    • Remove 000 phillips screws (4) from top of display.
  2. Sharp FX Digitizer/Screen Replacement: step 2, image 1 of 2 Sharp FX Digitizer/Screen Replacement: step 2, image 2 of 2
    • Remove 3 small silver screws from battery area.
    • Remove 2 Torx t-7's by MicroSD slot.
    • After screws are removed you can detach screen.
  3. Sharp FX Digitizer/Screen Replacement: step 3, image 1 of 3 Sharp FX Digitizer/Screen Replacement: step 3, image 2 of 3 Sharp FX Digitizer/Screen Replacement: step 3, image 3 of 3
    • Remove 4 additional 000 phillips screws from display.
    • Using some heat,spudger,frce pry away the broken display from the frame.
    • Use extreme caution the actual display is very fragile.
  4. Sharp FX Digitizer/Screen Replacement: step 4, image 1 of 3 Sharp FX Digitizer/Screen Replacement: step 4, image 2 of 3 Sharp FX Digitizer/Screen Replacement: step 4, image 3 of 3
    • Remove connector for digitizer
    • replace connector with new digitizer and rebuild.
  5. Sharp FX Digitizer/Screen Replacement: step 5, image 1 of 3 Sharp FX Digitizer/Screen Replacement: step 5, image 2 of 3 Sharp FX Digitizer/Screen Replacement: step 5, image 3 of 3
    • Reconnect to main motherboard.
  6. Sharp FX Digitizer/Screen Replacement: step 6, image 1 of 3 Sharp FX Digitizer/Screen Replacement: step 6, image 2 of 3 Sharp FX Digitizer/Screen Replacement: step 6, image 3 of 3
    • reassemble.
    • Enjoy the new display
jckoniecki
51 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,437
