Sharp PC-MM20 Keyboard Replacement
  1. Sharp PC-MM20 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • First, remove the battery from your laptop and make sure it is powered down.
  2. Sharp PC-MM20 Keyboard Replacement: step 2, image 1 of 2 Sharp PC-MM20 Keyboard Replacement: step 2, image 2 of 2
    • Close your laptop
    • Turn your laptop so that the back of it is facing you.
    • You should notice three screw. Remove those screws using the proper screw driver.
    • Be sure to put them somewhere safe, like a magnetic pad for instance.
  3. Sharp PC-MM20 Keyboard Replacement: step 3, image 1 of 1
    • Now, we're going to flip the laptop so it is upside down.
    • Remove the screws shown in the picture as well.
  4. Sharp PC-MM20 Keyboard Replacement: step 4, image 1 of 2 Sharp PC-MM20 Keyboard Replacement: step 4, image 2 of 2
    • Next, open the laptop and focus on the front of the base of the laptop.
    • Notice that there are small notches in between the two plates of the laptop
    • Take a flat edge and wedge it into the slot, and pop it open. There should be several of these slots on the front side of the laptop.
  5. Sharp PC-MM20 Keyboard Replacement: step 5, image 1 of 2 Sharp PC-MM20 Keyboard Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Once the cover is loose, you should be able to wiggle it somewhat freely. However, there are a few connections holding it together.
    • Next, we're going to use tweezers to delicately remove the flat cable connecting the key board to the laptop.
    • Also, remove the flat cable from the track pad to the laptop.
  6. Sharp PC-MM20 Keyboard Replacement: step 6, image 1 of 1
    • Now that all connections are undone, you should be able to easily remove the top of the base from the rest of the computer.
  7. Sharp PC-MM20 Keyboard Replacement: step 7, image 1 of 1
    • Next, you can take the key board out of its housing, and replace it with your new key board!
Logan Lindsey
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 594
