Sharper Image SBT5002 Speaker Replacement
  1. Sharper Image SBT5002 Speaker Replacement, Back Panel: step 1, image 1 of 2 Sharper Image SBT5002 Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Unplug the speaker before doing any work on it.
    • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
  2. Sharper Image SBT5002 Speaker Replacement: step 2, image 1 of 1
    • Remove the back panel.
  3. Sharper Image SBT5002 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the snap cable that connects the speaker to the circuit board.
  4. Sharper Image SBT5002 Speaker Replacement: step 4, image 1 of 2 Sharper Image SBT5002 Speaker Replacement: step 4, image 2 of 2
    • Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
  5. Sharper Image SBT5002 Speaker Replacement: step 5, image 1 of 2 Sharper Image SBT5002 Speaker Replacement: step 5, image 2 of 2
    • Use a plastic opening tool or spudger to pry off the front panel.
  6. Sharper Image SBT5002 Speaker Replacement: step 6, image 1 of 1
    • Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
  7. Sharper Image SBT5002 Speaker Replacement: step 7, image 1 of 1
    • Remove the defective speaker.
Linda Freund
235 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 557
