Sharper Image SVC430 SD Card Replacement
  1. Sharper Image SVC430 SD Card Replacement, SD Card: step 1, image 1 of 2 Sharper Image SVC430 SD Card Replacement, SD Card: step 1, image 2 of 2
    • Power off your device before you begin this SD card replacement.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 SD Card Replacement: step 2, image 1 of 2 Sharper Image SVC430 SD Card Replacement: step 2, image 2 of 2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 SD Card Replacement: step 3, image 1 of 2 Sharper Image SVC430 SD Card Replacement: step 3, image 2 of 2
    • Locate the micro SD port at the bottom of the device by lifting up the panel.
  4. Sharper Image SVC430 SD Card Replacement: step 4, image 1 of 2 Sharper Image SVC430 SD Card Replacement: step 4, image 2 of 2
    • To remove the micro SD card from the device, gently push the SD card and release. The SD card will pop out.
    • Be sure to gently push the SD card, pushing harder than necessary can cause the SD card or port to break.
  5. Sharper Image SVC430 SD Card Replacement: step 5, image 1 of 1
    • When putting a micro SD card back into the device, be sure to place the exposed metal side up, as well as have the device LCD screen side up.
  6. Sharper Image SVC430 SD Card Replacement: step 6, image 1 of 1
    • Gently push the micro SD back into the SD port until you hear a click!
    • Do not push the SD card hard. If it doesn't click, you may have the card the wrong way. Too much pressure can break the SD card or the SD port.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 384
