Sharper Image iPulse SI325 LED Lights Replacement
  1. Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: step 1, image 1 of 2 Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: step 1, image 2 of 2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 LED Lights Replacement: step 2, image 1 of 3 Sharper Image iPulse SI325 LED Lights Replacement: step 2, image 2 of 3 Sharper Image iPulse SI325 LED Lights Replacement: step 2, image 3 of 3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 LED Lights Replacement: step 3, image 1 of 2 Sharper Image iPulse SI325 LED Lights Replacement: step 3, image 2 of 2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
  4. Sharper Image iPulse SI325 LED Lights Replacement, Speakers: step 4, image 1 of 2 Sharper Image iPulse SI325 LED Lights Replacement, Speakers: step 4, image 2 of 2
    • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
    • Wiggling the connector back and forth as you pull will make removal easier.
  5. Sharper Image iPulse SI325 LED Lights Replacement: step 5, image 1 of 2 Sharper Image iPulse SI325 LED Lights Replacement: step 5, image 2 of 2
    • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
  6. Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: step 6, image 1 of 2 Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: step 6, image 2 of 2
    • Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights.
    • Slowly lift the circuit board out of the front cover and place the cover out of the way.
  7. Sharper Image iPulse SI325 LED Lights Replacement: step 7, image 1 of 2 Sharper Image iPulse SI325 LED Lights Replacement: step 7, image 2 of 2
    • Remove the solder connecting the LED light that needs replacement.
Melissa Pasa
701 Reputation
7 Guides authored
Cal Poly, Team 11-33, Amido Fall 2013 Member of Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 387
