Shenzhou k680e Silicone Grease Replacement
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: step 1, image 1 of 1
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: step 2, image 1 of 1
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: step 3, image 1 of 1
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: step 4, image 1 of 1
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: step 5, image 1 of 1
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: step 6, image 1 of 1
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: step 7, image 1 of 1
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: step 8, image 1 of 1
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: step 9, image 1 of 2 Shenzhou k680e Silicone Grease Replacement: step 9, image 2 of 2
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: step 10, image 1 of 1
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: step 11, image 1 of 1
    • Squeeze new thermal paste onto the chips.
Yizhen Qu
217 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 667
