Shoelace Aglet Replacement
  1. Shoelace  Aglet Replacement, Aglet: step 1, image 1 of 2 Shoelace  Aglet Replacement, Aglet: step 1, image 2 of 2
    • Remove the damaged aglet from the shoelace. You can either trim and peel it away from the shoelace or cut beneath the aglet itself and take it off completely.
  2. Shoelace  Aglet Replacement: step 2, image 1 of 2 Shoelace  Aglet Replacement: step 2, image 2 of 2
    • After you have trimmed away the damaged aglet there will be loose threads. These threads should be removed with the use of scissors with the goal of making it look as neat as possible.
  3. Shoelace  Aglet Replacement: step 3, image 1 of 1
    • Measure your heat-shrink tubing vs the existing aglet and trim to the length of the existing aglet.
  4. Shoelace  Aglet Replacement: step 4, image 1 of 1
    • With the freshly trimmed heat shrink tubing in hand, slide the tubing with a slightly larger diameter onto the shoelace where the damaged aglet used to be. Line up the end of the shoelace with the end of the tubing so they are perfectly lined up. (in photo we used 1/4"-1/8" tubing)
  5. Shoelace  Aglet Replacement: step 5, image 1 of 1
    • Taking caution to not burn yourself, heat the heat shrink tubing till it is shrunk tight around the shoelace. Use pliers to minimize the possibility of burning yourself while holding the tubing and shoelace in place (caution: will be hot)
  6. Shoelace  Aglet Replacement: step 6, image 1 of 1
    • Trim off any excess tubing for an even finish.
The goal is to replace the aglet with the heat shrink tubing. Be cautious not to burn yourself!
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 101
All Time: 7,879
