Shop-Vac MC150A Filter Cage Replacement
  1. Shop-Vac MC150A Filter Cage Replacement, Unlatch the power unit assembly: step 1, image 1 of 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Filter Cage Replacement, Remove the foam sleeve: step 2, image 1 of 1
    • Slide the foam sleeve up from the filter cage to remove it.
  3. Shop-Vac MC150A Filter Cage Replacement, Unscrew the filter cage: step 3, image 1 of 1
    • Use a 3.5 mm hex key to remove the two screws securing the filter cage.
  4. Shop-Vac MC150A Filter Cage Replacement, Remove the filter cage: step 4, image 1 of 1
    • Remove the filter cage.
Ngunlian
732 Reputation
5 Guides authored
IUPUI, Team 1-2, Baechle Spring 2016 Member of IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,814
