Shop-Vac MC150A Power Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Shop-Vac MC150A Power Cable Replacement, Unlatch the power unit assembly: step 1, image 1 of 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Cable Replacement, Remove the top cover: step 2, image 1 of 2 Shop-Vac MC150A Power Cable Replacement, Remove the top cover: step 2, image 2 of 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Cable Replacement: step 3, image 1 of 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Cable Replacement: step 4, image 1 of 1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Power Cable Replacement, Disconnect the switch: step 5, image 1 of 3 Shop-Vac MC150A Power Cable Replacement, Disconnect the switch: step 5, image 2 of 3 Shop-Vac MC150A Power Cable Replacement, Disconnect the switch: step 5, image 3 of 3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Power Cable Replacement, Unscrew the motor bracket: step 6, image 1 of 2 Shop-Vac MC150A Power Cable Replacement, Unscrew the motor bracket: step 6, image 2 of 2
    • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
  7. Shop-Vac MC150A Power Cable Replacement: step 7, image 1 of 2 Shop-Vac MC150A Power Cable Replacement: step 7, image 2 of 2
    • During reassembly, be sure to reattach the green ground wire clip to the bracket.
  8. Shop-Vac MC150A Power Cable Replacement: step 8, image 1 of 1
    • Separate the clip from the green wire and transfer it to the replacement motor.
3 other people completed this guide.
Ngunlian
732 Reputation
5 Guides authored
IUPUI, Team 1-2, Baechle Spring 2016 Member of IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Members
13 Guides authored
One Comment
How and where do I order a power cord? Just any power? Or a specific for shop vac.
Jenny Sellman - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 5,009
