Shop-Vac MC150A Power Switch Replacement
  1. Shop-Vac MC150A Power Switch Replacement, Unlatch the power unit assembly: step 1, image 1 of 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Switch Replacement, Remove the top cover: step 2, image 1 of 2 Shop-Vac MC150A Power Switch Replacement, Remove the top cover: step 2, image 2 of 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Switch Replacement: step 3, image 1 of 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Switch Replacement: step 4, image 1 of 1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: step 5, image 1 of 3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: step 5, image 2 of 3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: step 5, image 3 of 3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Power Switch Replacement: step 6, image 1 of 1
    • Use a spudger to pry up and remove the red switch from the housing.
6 other people completed this guide.
Ngunlian
756 Reputation
5 Guides authored
IUPUI, Team 1-2, Baechle Spring 2016 Member of IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 64
All Time: 17,879
