Shure SM58 Faceplate Replacement
  1. Shure SM58 Faceplate Replacement, Faceplate: step 1, image 1 of 1
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
  2. Shure SM58 Faceplate Replacement: step 2, image 1 of 2 Shure SM58 Faceplate Replacement: step 2, image 2 of 2
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  3. Shure SM58 Faceplate Replacement: step 3, image 1 of 2 Shure SM58 Faceplate Replacement: step 3, image 2 of 2
    • Slide the face plate over the connector.
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
nat coll
820 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
33 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 39
All Time: 9,645
