Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: step 1, image 1 of 1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: step 2, image 1 of 2 Shure SM58 Grille Replacement: step 2, image 2 of 2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Follow the steps in reverse to install the new grille on the microphone.
5 other people completed this guide.
nat coll
850 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
33 Guides authored
2 Guide Comments
Can you change the grilles of sm58 and sm86?
Jack - Reply Share
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Reply Share
Past 24 Hours: 7
Past 7 Days: 19
Past 30 Days: 68
All Time: 10,999
