Siemens A56 SIM Card Replacement
  1. Siemens A56 SIM Card Replacement, Battery: step 1, image 1 of 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 SIM Card Replacement: step 2, image 1 of 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 SIM Card Replacement, SIM Card: step 3, image 1 of 3 Siemens A56 SIM Card Replacement, SIM Card: step 3, image 2 of 3 Siemens A56 SIM Card Replacement, SIM Card: step 3, image 3 of 3
    • With the phone turned onto its backside, gently slide the metal clasp up to unlock the SIM card.
    • It may be easier to move the clasp with a plastic opening tool, but it is not required.
    • The SIM card will spring up once the clasp is released.
    • Remove the SIM card from phone.
  4. Siemens A56 SIM Card Replacement: step 4, image 1 of 3 Siemens A56 SIM Card Replacement: step 4, image 2 of 3 Siemens A56 SIM Card Replacement: step 4, image 3 of 3
    • To replace the SIM card, insert the card back into the slot.
    • While pressing the SIM card with one finger, slide the metal clasp down to lock the card in place.
Finish Line
Lauren Young
322 Reputation
3 Guides authored
Clemson, Team 6-6, Benson Spring 2014 Member of Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 556
