Introduction
The pulsation damper/pressure relief valve may be faulty, e.g. due to limescale. Remove it, check it or replace it.
''These instructions can also be used with other Siemens/Bosch models - the models have a similar structure.
Remove all attachments such as water tank, pulp drawer, brew group.
Remove the coffee container lid and take out all the coffee beans.
Lay the machine on its side with the water tank side facing up.
The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
The pulsation damper is mounted directly above the pump.
Pull off the clear hose.
Loosen the hose clamp on the red pressure hose and pull off the hose
Lock the outlet connection of the pump with a 12mm box-end wrench
Unscrew the valve. If it is not easy, you can also loosen the bayonet on the connection for the clear hose. Caution: a spring and a valve tappet may fall out.
The valve may just be calcified, in which case place the insides in a descaler. If you blow into the valve from the pump side, there should be hardly any resistance.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
