Introduction
If the coffee only flows into the drip tray and not in your cup the drainage valve maybe damaged. You can replace the gaskets or simply replace it with a new one.
These instructions may also help with other Siemens/Bosch models and with coffee makers from Nivona, Melitta, and Miele—they have a very similar design.
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
One Comment
My replacement valve (original Bosch part) didn’t fit correctly - after it was mounted, the light plastic part couldn’t be moved forth and back without getting stuck from time to time, so the machine wouldn’t be able to brew any coffee afterwards. I fixed it by reusing the light plastic part from the old valve. The machine works perfect now!
