Siemens Surpresso Compact microswitch on the drip tray replacement
  1. Siemens Surpresso Compact microswitch on the drip tray replacement, opening procedure: step 1, image 1 of 1
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Siemens Surpresso Compact microswitch on the drip tray replacement: step 2, image 1 of 1
    • Remove the two Torx T10 screws on the top.
  3. Siemens Surpresso Compact microswitch on the drip tray replacement: step 3, image 1 of 2 Siemens Surpresso Compact microswitch on the drip tray replacement: step 3, image 2 of 2
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Siemens Surpresso Compact microswitch on the drip tray replacement: step 4, image 1 of 2 Siemens Surpresso Compact microswitch on the drip tray replacement: step 4, image 2 of 2
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Siemens Surpresso Compact microswitch on the drip tray replacement: step 5, image 1 of 2 Siemens Surpresso Compact microswitch on the drip tray replacement: step 5, image 2 of 2
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Siemens Surpresso Compact microswitch on the drip tray replacement: step 6, image 1 of 1
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
  7. Siemens Surpresso Compact microswitch on the drip tray replacement, Microswitch on the drip tray: step 7, image 1 of 2 Siemens Surpresso Compact microswitch on the drip tray replacement, Microswitch on the drip tray: step 7, image 2 of 2
    • The micro switch is a little bit hidden behind cables. It is held by latches.
    • Push the cables aside, loosen the catches with a metal spudger and take the switch out.
    • Note how the cables are connected, disconnect the flat plugs and replace the switch.
    • Note: it may happen that only the carrier plate of the microswitch is no longer properly engaged. Tilt the machine so that you can see the base plate. See if the carrier plate is clamped with two catches. Press firmly on the microswitch until the plate engages. It may have to be replaced.
Follow the the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
247,794 Reputation
281 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,752 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,288
