Introduction
If the coffee only sprays weakly out of the two outlets, or only pours out of one of the two outlets, then they are probably blocked with coffee fat. It's difficult to properly clean the component as the aroma of the coffee will always suffer. The replacement part costs less than 4 euros, the replacement is extremely easy and will be described here.
The replacement of the coffee outlet in the Titanium line TK56001 makes more trouble, because you have to open the casing. The guide can be found here.
These instructions may also help with other Siemens/Bosch models and with coffee makers from Nivona, Melitta, and Miele—they have a very similar design.
To the left and right of the coffee outlet you will find two slots on the underside of the front cover.
Insert a spudger in the front edge of this slot and loosen the clips that fasten the front cover.
Pull the front cover forwards and off.
The image shows the machine after the front cover has been taken off. The four slots where the clips were are easily recognizable.
The movable coffee outlet is surrounded by a casing. Place an opening tool in the gap that separates the two halves of the casing.
Slide the tool along the gap, until the front casing becomes loose.
Remove the front casing.
4 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
