Singer 2263 Tradition Disassembly
  1. Singer 2263 Tradition Disassembly, Superficial rapid disassembly: step 1, image 1 of 3 Singer 2263 Tradition Disassembly, Superficial rapid disassembly: step 1, image 2 of 3 Singer 2263 Tradition Disassembly, Superficial rapid disassembly: step 1, image 3 of 3
    • Disassemble the screw that fixes the hood.
    • Disassemble the plate under the needle.
    • Disassemble the foot that contains the can.
  2. Singer 2263 Tradition Disassembly, Taking apart: step 2, image 1 of 3 Singer 2263 Tradition Disassembly, Taking apart: step 2, image 2 of 3 Singer 2263 Tradition Disassembly, Taking apart: step 2, image 3 of 3
    • Remove the side screws.
    • Remove the screws from the bottom (the upper left foot is also a screw)
    • Gently unclip the plastic cover
  3. Singer 2263 Tradition Disassembly, Bonus: Screw to tighten if the machine skates: step 3, image 1 of 2 Singer 2263 Tradition Disassembly, Bonus: Screw to tighten if the machine skates: step 3, image 2 of 2
    • If the motor and/or the white wheel at the end does not drive the main axis (and therefore at the end, no longer drives the needle)
    • It is then necessary to tighten the screw of the wheel, so that the whole no longer patinates.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
YvesG
290 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 81
All Time: 1,976
