Singing Machine Shine Duets LED Lights Replacement
  1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 3 of 3
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets LED Lights Replacement: step 2, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement: step 2, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement: step 2, image 3 of 3
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets LED Lights Replacement: step 3, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement: step 3, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement: step 3, image 3 of 3
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets LED Lights Replacement, LED Lights: step 4, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: step 4, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: step 4, image 3 of 3
    • Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
  5. Singing Machine Shine Duets LED Lights Replacement: step 5, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement: step 5, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement: step 5, image 3 of 3
    • Carefully remove the lightboard from the device, taking care not to damage any pins.
    • To reassemble, connect the pins on the lightboard to the motherboard.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 75
