Sink O-Ring Replacement
  1. Sink O-Ring Replacement, O-Ring: step 1, image 1 of 1
    • Locate both valves for hot and cold water. These are typically under the sink.
    • Turn off the water supply by turning each knob clockwise to stop the flow of water.
  2. Sink O-Ring Replacement: step 2, image 1 of 1
    • Put on gloves, as mold might be present.
  3. Sink O-Ring Replacement: step 3, image 1 of 1
    • Locate the screw insert in the sink handle.
  4. Sink O-Ring Replacement: step 4, image 1 of 1
    • Take out your screwdriver and attach the appropriate bit for your screw.
  5. Sink O-Ring Replacement: step 5, image 1 of 1
    • Insert the screwdriver into the screw in the sink handle, and rotate the screwdriver counterclockwise (left) to remove the screw.
  6. Sink O-Ring Replacement: step 6, image 1 of 1
    • Gently, but firmly, pull out the sink handle once the screw is removed.
  7. Sink O-Ring Replacement: step 7, image 1 of 2 Sink O-Ring Replacement: step 7, image 2 of 2
    • Once the handle is separated from the sink, clean it and its interior with an antibacterial spray, such as Lysol or Clorox.
    • If the sink has been linked for some time, mold has likely accumulated.
  8. Sink O-Ring Replacement: step 8, image 1 of 1
    • Remove the screw at the top of the O-ring.
    • If mold is present, clean the screw with disinfectant.
  9. Sink O-Ring Replacement: step 9, image 1 of 1
    • Using an adjustable wrench, remove the O-ring.
  10. Sink O-Ring Replacement: step 10, image 1 of 1
    • Replace the old O-ring with the new one.
  11. Sink O-Ring Replacement: step 11, image 1 of 1
    • Re-assemble the sink, reversing all steps used to disassemble the sink.
    • Congratulations! Once all the steps have been reversed and completed, feel free to test out your updated sink.
Finish Line
Brooke Don
193 Reputation
1 Guide authored
UC Davis, Team 2-8, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 2-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G8
2 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 61
All Time: 502
