Introduction
This guide helps your replace the daughter board for the control buttons. This guide will help you with any damage that has occurred to the control button witch contains the volume setup, skip button and the replay button.
Pry the speaker covers up gently from their sides by pulling up on the four corner posts that hold the cover in place.
Turn the device so that its front is visible.
Remove the channel dial by pulling up on the dial firmly.
Remove the S50 by pulling it up and off of its connecting posts.
Use an iFixit opening tool to pull up both sides of the speaker plate. They should come up easily. Pull firmly on the center to break the adhesive.
Remove four screws from the daughterboard using a Phillips #00 screwdriver.
