Introduction
This indicates the replacement of the speakers, that will help you with any static audio, quiet audio and fading audio. It will show you step by step of how to be able to fix and have better quality.
Pry the speaker covers up gently from their sides by pulling up on the four corner posts that hold the cover in place.
Turn the device so that its front is visible.
Remove the channel dial by pulling up on the dial firmly.
Remove the S50 by pulling it up and off of its connecting posts.
Use an iFixit opening tool to pull up both sides of the speaker plate. They should come up easily. Pull firmly on the center to break the adhesive.
Remove the two 7 mm screws using a Phillips #1 screwdriver.
Using a soldering iron, remove the side piece from each speaker.
