SiriusXM Onyx Plus Case Replacement
  1. SiriusXM Onyx Plus Case Replacement, Case: step 1, image 1 of 1
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Case Replacement: step 2, image 1 of 3 SiriusXM Onyx Plus Case Replacement: step 2, image 2 of 3 SiriusXM Onyx Plus Case Replacement: step 2, image 3 of 3
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Case Replacement: step 3, image 1 of 1
    • Once unclipped, separate the back casing from the device.
Angel Rivera
532 Reputation
5 Guides authored
USF Tampa, Team S7-G2, Passmore Spring 2018 Member of USF Tampa, Team S7-G2, Passmore Spring 2018
USFT-PASSMORE-S18S7G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 334
