Skil 88 Gears Replacement
  1. Skil 88 Gears Replacement, Disassembling Skil 88 Front Housing: step 1, image 1 of 1
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Gears Replacement: step 2, image 1 of 2 Skil 88 Gears Replacement: step 2, image 2 of 2
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Gears Replacement, Gears: step 3, image 1 of 2 Skil 88 Gears Replacement, Gears: step 3, image 2 of 2
    • Remove gear from the divider and add the new gear.
Matt
365 Reputation
7 Guides authored
Cal Poly, Team 5-17, Maness Fall 2010 Member of Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 2,197
