Skirt Lining Replacement
  1. Skirt Lining Replacement, Lining: step 1, image 1 of 2 Skirt Lining Replacement, Lining: step 1, image 2 of 2
    • Cut out the old or damaged skirt lining. This can be done using a pair of scissors, or a razor blade/seam ripper if you have one.
    • Blades might give you a neater finish after this step but take longer to use.
    • Be careful when using sharp objects.
  2. Skirt Lining Replacement: step 2, image 1 of 2 Skirt Lining Replacement: step 2, image 2 of 2
    • After threading the needle, take some new lining (chiffon or silk material), iron it out, and make sure the lining isn't longer than the actual skirt.
  3. Skirt Lining Replacement: step 3, image 1 of 3 Skirt Lining Replacement: step 3, image 2 of 3 Skirt Lining Replacement: step 3, image 3 of 3
    • Gently insert the threaded needle. Be careful not to prick your finger.
    • Push through the skirt fabric from below.
    • Pull the needle all the way out to form a stitch.
  4. Skirt Lining Replacement: step 4, image 1 of 1
    • Continue with step 3 until you create stitches around the whole waistband of your skirt.
    • It should look somewhat like this when you make it halfway around the waistband of the skirt.
  5. Skirt Lining Replacement: step 5, image 1 of 1
    • Cut out extra fabric if you have any, and here's what the waistline of your skirt should look like.
    • Try it on!
Finish Line
Rena
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 508
