Skullcandy Air Raid Battery Replacement
  1. Skullcandy Air Raid Battery Replacement, Rubber Cover: step 1, image 1 of 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Battery Replacement, Handle: step 2, image 1 of 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Battery Replacement, Front Plate: step 3, image 1 of 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Battery Replacement: step 4, image 1 of 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Battery Replacement, Speakers: step 5, image 1 of 1
    • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
  6. Skullcandy Air Raid Battery Replacement: step 6, image 1 of 1
    • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Battery Replacement: step 7, image 1 of 1
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Battery Replacement: step 8, image 1 of 1
    • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Battery Replacement, Control Buttons: step 9, image 1 of 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
  10. Skullcandy Air Raid Battery Replacement: step 10, image 1 of 1
    • Lift the button panel.
  11. Skullcandy Air Raid Battery Replacement, Button Motherboard: step 11, image 1 of 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  12. Skullcandy Air Raid Battery Replacement: step 12, image 1 of 1
    • Using a plastic opening tool, pry the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  13. Skullcandy Air Raid Battery Replacement, Ribbon Cable: step 13, image 1 of 1
    • Pull the black ribbon cord attachment away from the motherboard.
    • Pull on the cable until it releases from the back of the motherboard.
    • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
  14. Skullcandy Air Raid Battery Replacement, Back panel: step 14, image 1 of 2 Skullcandy Air Raid Battery Replacement, Back panel: step 14, image 2 of 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
    • Lift off the back panel.
  15. Skullcandy Air Raid Battery Replacement, Battery: step 15, image 1 of 1
    • Pull on the ribbon cable that connects the battery to the motherboard until the connector releases.
  16. Skullcandy Air Raid Battery Replacement, Removing Battery: step 16, image 1 of 1
    • Pull battery straight out until it is completely out of device.
    • If you are unable to loosen glue contact, use a heat gun to assist in removal.
6 other people completed this guide.
6 Comments
Hi, my name is Alex, and i have the same problem. The battery does not work anymore, but i don't know where can i find a replacement, and what is the its name. Or mabe something similar? I live in Romania so i need mabe an international online store to buy it. Thank you! My email is stanciualex_e@ yahoo.com
Alex - Reply
What is the type of battery?
grigoriev85 - Reply
I have the same issue. I want to acquire a replacement.
It is a rechargeable battery Model AEC553450-2P / 2000mA 3.7V 7.4Wh.
It there anybody out there who could help us I will appreciate it very much
Fernando Morales - Reply
I also need a battery, have you found one?
Noah Larsen -
Noah Larsen - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 49
All Time: 9,421
