Skullcandy Crusher Wireless Bluetooth Antenna Replacement
  1. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: step 1, image 1 of 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: step 1, image 2 of 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 2, image 1 of 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 2, image 2 of 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 3, image 1 of 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: step 4, image 1 of 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: step 4, image 2 of 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
  5. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 5, image 1 of 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 5, image 2 of 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 5, image 3 of 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker assembly away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 6, image 1 of 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 6, image 2 of 2
    • Separate headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: step 7, image 1 of 1
    • The Bluetooth antenna module chip is located on the right top corner of the motherboard.
    • If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Val
1,104 Reputation
6 Guides authored
One Comment
Where can one purchase a replacement chip?
Josh - Reply
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 50
All Time: 1,023
