Skullcandy Crusher Wireless Earpiece Speaker Replacement
  1. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: step 1, image 1 of 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: step 1, image 2 of 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 2, image 1 of 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 2, image 2 of 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 3, image 1 of 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: step 4, image 1 of 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: step 4, image 2 of 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 5, image 1 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 5, image 2 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 5, image 3 of 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 6, image 1 of 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 6, image 2 of 2
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 7, image 1 of 1
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
  8. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: step 8, image 1 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: step 8, image 2 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: step 8, image 3 of 3
    • Remove four 4 mm Phillips #1 screws that connect the motherboard with the plastic frame.
  9. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 9, image 1 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 9, image 2 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 9, image 3 of 3
    • Remove three 4 mm Phillips #1 screws that connect the bass speaker to the plastic frame.
  10. Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 10, image 1 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 10, image 2 of 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: step 10, image 3 of 3
    • Move the motherboard away from the plastic frame.
    • Desolder two cables to replace the speaker and bass component.
Val
1,104 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 115
All Time: 2,499
