Sky 6.0Q Battery Replacement
  1. Sky 6.0Q Battery Replacement, Battery: step 1, image 1 of 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: step 2, image 1 of 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: step 3, image 1 of 2 Sky 6.0Q Battery Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: step 4, image 1 of 1
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: step 5, image 1 of 1
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: step 6, image 1 of 1
    • Once separated, remove battery and replace with a new battery.
2 other people completed this guide.
Monica Difato
429 Reputation
2 Guides authored
IUPUI, Team S1-G3, Hovde Fall 2018 Member of IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 36
All Time: 2,416
