Sky 6.0Q Front Camera Replacement
  1. Sky 6.0Q Front Camera Replacement, Front Camera: step 1, image 1 of 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Front Camera Replacement: step 2, image 1 of 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Front Camera Replacement: step 3, image 1 of 2 Sky 6.0Q Front Camera Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Front Camera Replacement: step 4, image 1 of 2 Sky 6.0Q Front Camera Replacement: step 4, image 2 of 2
    • Disconnect the electronic adapter connecting the camera to the top mother board.
    • Once disconnected, remove the camera and replace with new camera. If necessary, use the spudger to help remove the camera.
    • To reattach front camera electrical connection, gently press piece back in place.
Robert Berardi
247 Reputation
2 Guides authored
IUPUI, Team S1-G3, Hovde Fall 2018 Member of IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 285
