Sky 6.0Q Top Motherboard Replacement
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: step 1, image 1 of 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: step 2, image 1 of 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: step 3, image 1 of 2 Sky 6.0Q Top Motherboard Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: step 4, image 1 of 1
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: step 5, image 1 of 3 Sky 6.0Q Top Motherboard Replacement: step 5, image 2 of 3 Sky 6.0Q Top Motherboard Replacement: step 5, image 3 of 3
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: step 6, image 1 of 1
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: step 7, image 1 of 1
    • Once the screws are removed, gently lift the top motherboard and replace.
Monica Difato
429 Reputation
2 Guides authored
IUPUI, Team S1-G3, Hovde Fall 2018 Member of IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 513
