Sky Thunder HD 8500WH Lockstich Replacement
  1. Sky Thunder HD 8500WH Lockstich Replacement, Rotor Blade: step 1, image 1 of 3 Sky Thunder HD 8500WH Lockstich Replacement, Rotor Blade: step 1, image 2 of 3 Sky Thunder HD 8500WH Lockstich Replacement, Rotor Blade: step 1, image 3 of 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Lockstich Replacement, Lockstitch: step 2, image 1 of 2 Sky Thunder HD 8500WH Lockstich Replacement, Lockstitch: step 2, image 2 of 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 125
