Sky Thunder HD 8500WH Lower and Upper Body Replacement
  1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: step 1, image 1 of 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: step 1, image 2 of 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: step 1, image 3 of 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: step 2, image 1 of 2 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: step 2, image 2 of 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: step 3, image 1 of 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: step 3, image 2 of 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: step 3, image 3 of 3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Lower and Upper Body Replacement: step 4, image 1 of 2 Sky Thunder HD 8500WH Lower and Upper Body Replacement: step 4, image 2 of 2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 140
